Results 1 to 6 of 6
    DW 5600e Problem
    I've had this watch for 3 months shy of 2 years. When I turn on the light. It's hard to read the numbers. This just started to happen. Why?
    Update. When I turn on the light. The digital read out disappears. The screen goes blank. Battery? But less than 2 years use. The only feature I use is the light. I thought the battery is good for 3 years? I've heard the battery is good for 10 years? What gives?
    Hong Kong
    Quote Originally Posted by phatjack View Post
    Pls post a few photos
    I don't have the equipment or expertise to post photos.
    Hong Kong
    DW 5600e Problem
    Ok .. It sounds to me like it needs a new battery. If you don't use the EL backlight too much, the battery may last 5 or 10 years. The more backlight use, the shorter the battery life. Thatís the reason many prefer solar watches. You may check on YouTube videos about DW-5600E battery change. Thereíre some! Also thereíre a couple of posts about this topic on the internet. Check it out. Good luck!
  7. 1 User Likes This Post
    MacLaren (2019-07-02)
  8. #6
    Got new battery. Problem solved. I lust after tough solar.
  1. G-5600E vs. G-5600E-1JF
    By Denver Guy in forum G-Shock & Casio Chat & Discussion
    Last Post: 2016-09-08, 03:10
  2. DW-5600E Variations
    By mpq in forum G-Shock & Casio Chat & Discussion
    Last Post: 2014-03-24, 07:28
  3. Stuck in buttons on DW-5600E
    By Amontgomery in forum G-Shock & Casio Chat & Discussion
    Last Post: 2011-10-30, 07:11
  4. eBay Japan Casio x DevilRobots To-Fu Oyako G-Shock Limited Edition DW-5600E
    Last Post: 2011-10-29, 21:50
